Transfer of E-mail address data base.
I have lost my e-mail database. My wife has most of the same addresses. How can I export her's to my computer - we are networked. Following the instructions for exporting addresses seems to run OK but I have no idea where - if at all the "exported" file has been put. Both of us are using Outlook Express.
vic_newey
my outlook address book is in ' my documents folder ' send it there for sure
Lost E-mail address database
THanks very much. I'll look there.
Do a search for *.wab ie windows address book and just copy it,
search *.dbx and you will find your email collection that can be copied too!.
In OE options you can setup your own address ie 'My Documents' which points to where you want to place the email files.
:lol:
