Transfer/copy of files with "too deep" comment
I am currently trying to transfer/copy .biz files from a CD to another drive. I keep getting a message "cannot copy: the path is too deep". Can find no mention in any of the reference guides or help files about this subject or whether there is a file restriction on size. The file I am attempting to copy is 74,936 KB. Any advice welcomed.
Fixes: 57
I think it refers to the depth of the folder path but I am surprised that you hitting that limit
Have a look at this
Walrus
The ISO9660 CD format only allows a depth of 8 directories (folders) from the root, whereas the windows filesystem allows any depth (total length shorter than 260 characters).
I suspect this is the issue.
Fixes: 8
If it's a problem with the target I think you can create a share of a directory well down the path and map a drive to it to work round the problem.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Denzil
Re: Transfer/copy of files with "too deep" comment
This sounds like a philosophical problem Cool
shellsong
If a tree fell in a forest on Schrodinger's Cat, would the cat be alive or dead? Cool
