Thunderbird?
Thunderbird?
Hi
I notice in the Plusnet newsgroup a number of persons use "Thunderbird"
I'd like to ask a question if I may.
I downloaded and installed "Thunderbird" to my wifes Windows computer to move her away from MS products (she uses "Firefox" as her browser).
However I could not work out a way to get "Thunderbird" to just download the article headers without the message bodies.Is this not possable with "Thunderbird" or did I miss something simple?
IanJ
1 REPLY
lingbob
Re: Thunderbird?
Right-click on your account in the left-hand pane and then click on "Properties".
Click on "Server settings" and you should see an option "Fetch headers only".
Enable this and you should be set.
Martin
