The perfect modem - suggestions?
My knowledge might be little but I know my modem is probably not the most adequate for my internet consumption. Downloads are painfully slow and I cannot blame it (all...) on the provider. The one I have is a ADSL ROUTER ART514CX. I was told by a friend that my downloads are slow(Torrent) because this modem doesnt accept many connections at the same time. While I use the internet a lot, I am almost completely ignorant about the technical issues so can anyone recommend the best modem option for me? Just so I can get some kind of research started.
Thanks in advance.
do you happen to run XP with SP2 as well? as that can cause torrents to fail miserable. Any how what you want is a nice linksys one, just check their site out then find one on ebuyer.co.uk Smiley
buz
There IS a way of using XP without SP2? I am pretty sure I downloaded it some time ago...
Linksys uh? Thank you for the suggestion,will do some research.
