Terrestrial TV Digibox
pimpernel
If I could connect a digibox direct to a LCD monitor, would I get a picture, assuming appropriate digi-aerial is connected?
If so, what connectors/cables/hardware would I need?
pimpernel
If this is a stupid question, then please, someone, tell me I'm stupid.
But I can see no logical reason why it should not work.
rja66
Funny that, my wife asked me the same question the other night. My answer was similar to yours, i cannot see a reason why not :?
I can.
You would need the appropriate connectors on each, which they do not normally come with.
You will need a LCD TV to do this.
There is no import tax on LCD computer monitor, but there is on LCD TV's
Chilly
Typo corrected
Hmm, looks to me like you need to buy a SCART to D-SUB cable.
Maplin will sell you one for about £60, Courageshop will sell you one for £45 inc shipping.
Maplin and Courageshop
If you are into electronics, you can build one yourself (some circuitry is needed to merge the signals to end up with a composite signal rather than the SCART output)
Its on my list of things to buy - esp. since a TV tuner is no use where I live, the only TV signal we can get is via Satellite or Cable, so I'm planning on just using a spare LCD monitor in the bedroom plugged into the SKY box.
EDIT: Added Links
pimpernel
Interesting that it should work if you can get a cable, but the cost of the cable negates the savings you make by getting a monitor instead of a TV.
£60 or even £40 sounds way too much to me.
£5-£10 sounds about right with a guarantee that it'll work.
Not into making cables myself.
Thanks, all. Perhaps I'm not so stupid after all.
