Swap-File
Swap-File
Does the "SWAP-FILE" have a proper name? Is it possible to open see what it contains, can it be deleted?
I would be interested to receive any information about this file please
Alecto
Swap-File
Google has lots of good stuff about swap files.
Swap-File
a swap file is just that, it swaps data around and stores it.. just like RAM
yes, you can open it in a hex editor and see whats inside, lots of passwords and stuff.. good insecurity going on Smiley
you can turn off swap files under properties of my computer
Swap-File
I'd be careful about switching off your swap file, as someone software requires the swap file even if you've got massive amounts of ram.
Swap-File
I have a hex editor but I do not know what the name of the swap file is, can someone tell me please.
I have trawled through the google references to Swap file and most of them are only coincerned with making it a fixed size or letting it remain flexible and there does not seem to be a definitive answer to that.
I have no intention of turning it off but I want to look at it as part of some research that I am doing. I just need to know the name of the file and its extension.
the_norris
Swap-File
The file is call 'pagefile.sys' in the root of C: by default.
You can move which drives the swap file is on via the control panel.
holdtight
Swap-File
You will have to go into folder options and make sure you can see all hidden and system files before you will be able to find it
