Stuffy computer tip
Stuffy computer tip
For anyone with a stuffed up nose buy a little pot of Vicks chestrub, get some tissue and then clean the pc with it. Great for the pc and the room.(do not if you have resprayed pc)
michaelscott
Stuffy computer tip
You could even attach a pot of it near the PSU exhaust fan to circulate the aroma around the room Cheesy
Stuffy computer tip
Another tip is to place a few smelly unlite candles at on top of the monitor, that is if you haven't gone and bought one of those silly flat things.
Stuffy computer tip
Candles, unlit or not, are not a good idea on top of the monitor. The tempartaures can get hot enough give off flammable vapours.
Vicks is non-solvent based, so it is alright.
Stuffy computer tip
It's an old trick and it's fine
Stuffy computer tip
Better still invest in one of those fancy heat pump cpu coolers with integrated aromatherapy oil heater. They do exist - it was in print so it must be true!
michaelscott
Stuffy computer tip
Wouldn't a methol based substance like Vicks keep your CPU nice and cooooool? Cheesy
