Start up!
Rourkefamily
Start up!
Busy tonight :roll:
My darling daughters use MSN on the PC. When I log on to my section of the computer MSN starts up automatically :x
How can I change this?
Start up!
Go to the control panel and then Add or remove programs or Windows compnents.
Under the windows components option find MSN and remove the tick.
Next time you bootup the PC it wont start. (MSN that is not the computer Smiley )
Start up!
Or open up MSN, go to - Tools - Options - General - on the right - uncheck the tab that says 'Automatically run messenger when i log onto Windows'
