Standby Problems
Standby Problems
Since getting a broadband connection if I put the PC into "standby" mode after about 15 mins. it comes back on and will then switch between on and standby approx. every 15 mins.
Any suggestions please.
Standby Problems
Your connection or network card could be set to "allow this device to bring the computer out of standby".
From you control panel go to system-hardware-device manager. Select the propertuies for your network connection and generally under the Power management tab you will see the option to enable or disable this function.
That should sort it.
Standby Problems
Thanks for your advice, when I checked the box was ticked but sowas another,"Allow computer toturn off this device to save power" I unticked this box and it appears to have worked.
Again thans very much for your help.
