Sound with PC and Xbox 360
Sorry for being dim but I can't seem to get my xbox 360 and PC to work with my Logitech 2 channel speakers.
The setting I tried was a cable from my OUT on PC to my Right and Left Red/white in sockets on the LCD and my 360 plugged into the LCD via a RGB scart cable. I got OK sound from the 360 (as OK as you can get with 2 channel) but distorted and weak sound when using the PC.
And what other options do I have if I was to get a 2.1 sound setup.
Any help appreciated
Your sound card should have a out(or speaker) and a line out they are different inpedance and it should be line out if there is an amp and speaker if there isnt.
Some cards change the sockets via software so out may not be out check your sound card software to see if its setup right
Please could someone talk me through how I get an xbox and my PC working together using normal PC 2 channel speakers. The speakers on my small lcd are pathetic so would appreciate some advice.
