Some help with event viewer
Win XP event viewer is giving me this message as a warning - source atapi event 26, The driver has detected that device \Device\Ide\IdePort0 has old or out-of-date firmware. Reduced performance may result.
The msoft Help and Support Center is not much help. I can guess it's one of the drives causing this, but can anyone suggest how I identify which one? I've 2 HDs, 2 CD, and a floppy.
I'd like to try and fix it before something fails.
Thanks all.
1 REPLY
neutrino
The following link will take you to a site which helps with event errors
http://eventid.net/display.asp?eventid=26
If you scroll about half way down the page you will find your particular error. If you click on the details link you will be offered possible solutions found by other users
Best of Luck
Alan
