Solwise 110/Dlink624+ configuration?
Hello!
I have a solwise110 which was supplied with my Plusnet starter pack.
It works fine but then I bought a D-link 624+ wireless router for wireless operation.
Basically I want 2 pc's wired and 2 laptops wireless sharing broadband through the Solwise and Dlink, with the Dlink configured so access is by entering a password
However they are both routers( I should have simply got an access point)
and there's a bit of fiddling around with the configurations before they work.
At the mo I have the Solwise ethernet out going out to a Netgear Hub,
2 pc's are plugged into the hub and the Dlink is also connected to the hub on default setting on for wireless to but I want to get into the dlink to configure it for passwords and WEP but I think it conflicts with the Solwise router Config Setup.
Can anybody help?
1 REPLY
the_norris
Copy of this thread here - http://portal.plus.net/central/forums/viewtopic.php?t=14105&highlight=
Support been done in the above thread.
