Slower speeds on Shareaza using 1MB than 512k??!?!?!?
Hi all!
I moved to the 1MB connection with PlusNet from the 512k connection with *spits* FreeServe.
However, since moving, I have noticed my dl and ul speeds in Shareaza have actually decreased.
I have set the software up correctly, and even re-installed it. however, the highest overall DL speed I can get is around the 140KB mark. The graph at the top shows the speeds as really, really slow.
Also (don't know if it's related) my Xbox live speed appears to be a lot slower now as well......
I am using a Binatone ADSL2000 modem (changing to a netgear modem/Router today).
Any advice would be greatly appreciated!
1 REPLY
Brickinit
have you taken a look at the service status today, maybe a reboot of your router, i guess you will get that whilst installing your new one, but if you can leave it off line for 30-60 mins it can make a huge amount of difference. also when i installed another netgear modem albiet a second hand one it incresed my speeds considerably
