Sil 680A ATA133 Pci Card
Hi peeps, dunno if any of you could help me but i have hit a snag.
Trying to hook up 2 dvd burners to the ata133 card.. but when xp is booting i get a stop message.. PAGE_IN_UNPAGED_AREA.
Unplug them and it boots fine.
Plug a couple a hard disks onto it.. boots fine :x
Pretty stumped Cry
Thanks,
Louis
The unpaged area is a section of memory used for code that is so
critical that it may not be paged out. So it is intended for system
code that is fully trustworthy. This fault can be caused by faulty RAM,
but in your case I suspect third party software getting in on the act
and installing itself there. I understand some aspects of Norton
(Internet Security?)
It could be your card is using the wrong part of ram and causing the problem. Try another slot for the card and check for new drivers.
The details of the error can be found
http://aumha.org/win5/kbestop.htm
Number 50 on the left menu
Is it by any chance a RAID card ?
Regards, John Taylor.
it is the ide version.. i just find ot strange that hard disks work fine on it.. but dvd burners wont Cry
http://www.siimage.com/products/product.aspx?id=31&ptid=1
Gave up trying.. shoved a hdd on each channel as masters.
No probs Smiley
suppose 1 dvd burner is enough lol
Just out of curiosity, why 3 burners ? Are you going into production ?
Edit
I suppose you've tried uninstalling the device in hardware manager, switch off, fit your 2 DVD drives as masters and re-booting ?
tryed everything..
just i have an old 8x dvd and just bought a new 16x one lol
least my new one can unlock starforce protected discs.. unlike the 8x.
couldnt get many games to run. because it couldnt verify the cdkey embedded in the original cd.
one will suffice lol
