Shares and restore
Shares and restore
at work we had a shared area that we backed up which had shares and permissions
We tried restoring that folder in a different machine, all shares were gone but permisisons were thier? any ideas on how i can get the shares back
we also tried restoring that folder in the same machine but shares were still not appearing?
Re: Shares and restore
Are you using rsync?
rsync -ave ssh --delete machine_name:/path/to/directory/to/copy .
it should preserve all permissions etc set on the original file system and copy them to the new location.
MysteryFCM
Shares and restore
Question is, did you backup the shares at the system level, or just the shares at the file system level?.
If you backup shares including settings, these will be restored perfectly when needed. However, if you only back them up at the file system level then whilst the files/folders will be restored, the share settings for them will not be (permissions are attatched to the files/folders so are seperate from the share settings).
