Setting up a Wireless connection
I have a netgear Modem/router with four lan outputs and two computers connected to it.
I want to add a third computer by wireless. I think I need a wireless acces point to plug into the Modem/Router (is that right) but what do I need to plug into my receiving computer? There is no PCI slot available, it would have to be something that connected to the USB or firewire. Is that possible? Please advise me
Yes, you need a wireless access point plugged into your router, and yes you can get USB wireless network adaptors.
Thanks for reply I will now browse the web for the required components
