Selection of usernames
I am running windows 2000 professional and IE 6. In using the plusnet website, I have somehow managed to type my email password into the username box on the members centre email logon box. Now when I start to type in my username my password becomes a selection of a drop down list for all to see! Shockedops:
Is there anyway I can delete this?
Alecto
When I used IE, if you highlight the entry after it has filled it in and press delete, that should delete it.
Thanks for the quick response.
Unfortunately deleting as you suggest does not work. I would suspect that there is a file somewhere with the usernames in but I do not know what it is called or where is lives.
Any ideas?
If you clear out your cookies, (Tools>Internet Options) that will get rid of the file holding the details!
Alternatively - change your password Wink
Good idea but the details are still there ! Cry
Any other suggestions (I would rather not have to change my password)?
Alecto
Tools
Internet Options
Content
Autocomplete
and turn it off/clear the stuff there
Fantastic, that worked a treat. Many thanks for everyones time and effort.
Alecto
A further thought
If you download and install the free C*** Cleaner utility, one of the items you can choose to clean is your autocomplete history.
C Cleaner is a brilliant utility anyway, and helps to clean up all kinds of loose ends on the computer.
also a god tip is to never tell internet explorer to remember your password on a site.
It is possible to extract them from the protected storage of the registry quite easily
Its very easy to retrieve system (logon) passwords from a Windows box too, so since logons can't be secured properly, any password stored under your username becomes much more of a liability.
Admittedly somebody needs physical access to your machine, and the ability to boot from CD-ROM, but in the event of a theft of your machine (which becomes much easier, and more likely as more of us use notebooks) the danger becomes a reality.
Apparently Vista changes the storage methods and locations for password details, but it probably won't take long for tools to be available to retrieve passwords from a Vista box.
/wonders if Sentinal Card Protection extends to cover web logon details and organisations.
