Security Tab on NTFS Partition
Hi ,
I've splitted my harddrive into 4 partitons (all NTFS) but when I right click on any of them and check the properties, I can't see the "Security Tab" anywhere. Could somebody please tell me how to activate it ? ? ? ? ? I need to assign rights for different users on different partitions.
thanks
shez
Shez,
How exactly are you wanting to give these permissions and access? Is it on your local machine on win xp home or is the hdd located on a server etc etc.
Regards,
Use an admin account then;-
Control panel > Folder Options > View(Tab) > then uncheck "Use simple file sharing"
I think thats it anyhow.
