Script Errors With Windows Live OneCare Service Scan
Has anyone else got this problem with the Windows Live OneCare service scan http://onecare.live.com/site/en-gb/default.htm ?
I've been using this for some time as a registry cleaner but recently I've been getting the following script errors:
An error has occurred in the script on this Page
Line: 2
Char: 1
Error: Invalid character
Code: 0
URL: about.blank
I've googled for this and have found some old references to problems with IE7 however these seem to have been fixed plus I've been successfully using it with IE7 for some time.
The problem seems to coincide with when I installed Adobe Reader v8 but I can't be sure.
Thanks - Bob
Its a MS site what do you expect? Could be because they upgraded their servers to win2008 BETA.
Try clearing your cache as it may be a cached paged its just saying there is a invalid character on the page.
Hi I've tried that thanks. I assume this can't be a widespread problem or there would be more comment about it on-line.
Which (free!) registry cleaners do other use?
Bob
Edited to correct spelling mistake.
Denzil
TweakNow is fairly basic but seems to work quite well. Free download from http://www.tweaknow.com/RegCleaner.html
