Screen Capture
Screen Capture
Does anyone know what software I could use to enable me to save a paused real media video clip as a jpg etc? I've tried the "print screen" button but that produces a blank space where the video is on the screen and I've also tried "Crystal Player" to no avail. Any other ideas?
Cheers,
Tim.
Screen Capture
I found a program called Any Capture Screen (a quick search on google will find the url) which can capture screenshots of media files however its not free, im pretty sure there is a shareware version avalible.
Hope this helps.
Screen Capture
Thanks for that. I went to the homepage for Any Capture Screen and there was a question posted as to why you get a blank screen when capturing video stills (the problem I was having) and they suggest turning off hardware acceleration. I did that and it works now! Didn't even need their software Smiley I'll keep a note of it however just in case it becomes usefull in the future.
Many thanks for your help.
Cheers,
Tim.
