SMTP Problems on SuSe?
While running SuSe Personel 9.1 i have problems using SMTP. This happens with KMail and also Mozilla Thunderbird.
All the settings are the same as Outlook Express, which runs fine.
Any ideas on a solution?
Cheers.
See this thread where exactly the same issue was discussed and solved.
Perhaps using the search facility next time could help when looking for answers Wink
uuurrggghhh i should really know better. Didnt think many people would have had a play with Suse and kept to stuff like Knoppix and Fedora.
*slaps self*
Moderators note (John) Quote removed as it was just a complete copy of the previous post and not needed.
