SD cards
morgan2476
SD cards
Is it true that the larger the size of an SD disk that it draws more power from the battery?
SD cards
no
morgan2476
sd cards
the 32mb card i got with the camera seems ok. When i put in the 512mb card it seems to drain the bat very quickly
Midville
SD cards
Turning off the lcd display will save alot of power............. just use the view-finder.
Alecto
SD cards
It doesn't make any sense to me, but if you Google on SD card battery drain, quite a few people seem to think that SD cards cause a serious drain on the battery just by being there.
I'd try asking the manufacturer of either card or the device to see if they admit anything.
