SAR130 firewall
SAR130 firewall
Hi All
Where in the configuration of the SAR130 router do I find the option to dis-able the firewall assuming of course this is possable?
Ian & Linda Jordan
SAR130 firewall
A bit of an update although it makes things a little more of a puzzle.I downloaded the manual for the SAR130,and now know where to go to change the firewall setting.However clicking on any of the tabs does'nt change anything for example I log into the router and get to the home page,click services which should give access to the firewall but the screen remains on the home page.......... what am I neglecting to do?
Ian & Linda Jordan
SAR130 firewall
Ian & Linda Jordan
SAR130 firewall
oops sorry about the double posting folks.
Ian & Linda Jordan
painswck
SAR130 firewall
cannot help you with the SAR130, I have the 110. have you tried the forum on the Solwise site. A very helpful crowd seem to hang out there and someone may point you in the right direction.
Cheers
Roland
SAR130 firewall
The firmware /setup is the same for both units,
I wonder if it's a browser problem ?
Alec
SAR130 firewall
Hi aleca
Yes it was...... I never considered that thanks,but I now discover that there does'nt actually seem to be a way to disable the firewall,and on the firewall screen everything seems to be set to disabled so back to the drawing board.
Thaks again your short reply is most appreciated,and "Internet Explorer" does have it's uses :-)
