Routers!
Routers!
Hi there ,looking for help desperately,I am running a Mac OSX system,just updated my router Zyxel P66iH ,supposed to come with Zero config,but will not connect at all,plug my old one in and,well your reading this,anybody ideas,links ,faqs,any idea,been at it 3 days now tried every config going HELP! :?:
Routers!
need to put a little more info than that in, what kind of router? router/modem all in one? or seperate modem hooked up to router?
Routers!
Some Zyxel routers are very bad at connecting. PN have now dropped their version due to many people not getting it to sync with the exchange. It was apparently caused by a bad batch of chips so it's possible that bad batch was used for other Zyxel models and thus suffer the same thing.
Best bet if this is a new router is to return it and get a netgear DG834 instead - or 834G if you need wireless - which is very simple to setup.
