Router help.
Hustler85
Router help.
I have just got a new router and I am trying to get it connected.
The router is an eTEC with 4 ports. I'm not to great on dealing with these sorts of problems but I do know alittle.
I have entered all the settings needed and still nothing. Sometimes it says connected but doesnt allow me to browse and sometimes its says limited or no connectivity.
I know this is hardly much information to work off but let me know any info I can give to help and I will do so.
Any help in anyway will be greatly appreciated.
Thanks.
Router help.
http://www.peteashton.com/02/12/07/the_informal_etec_pt.html
There are things worth looking at on that website.
Conexant chipsets are always a nightmare! Are you connecting via usb or ethernetHuh
If you have a router forget usb go straight to ethernet. However, I am assuming you are already doing this!!!
maybe your connection requires a phone number such as 0,38 or p0,38?
most I agree do not but a few do.
router probs
If you are talking broadband router it sounds like you have paired your computer and the router up, you need to open a web browser to get to the connect control panel, remember to enter your user name and password if needed. This happened to me when I went from usb to ethernet with my Mac when the system upgrade wiped out usb modems. I now use a Netgear router, which is fabulous.
Good luck.
