Restirct network bandwidth
jlpappin
I want to restrict bandwidth on my network at home. We flew past the 20GB limit already and I know before the end of the month the people I live with will pass the limit. So what I want to do is using the Netgear routers I have is throttle the bandwidth. Everyone is on a wireless connection except me since I am wired to it.
Our set up is like this.
Internet
DG814
Netgear wireless router
Then everyone just connects to the wireless router. Is it possible using this hardware to restrict bandwidth. we would be fine if I could restrict each user to say 500MB per day. Even better perhaps a way to restrict them just on peak time. I know I am asking a lot but I am willing to learn.
Your best bet would be a proxy server as most of them have this function and you can also restirct sites. If you do a google search for proxy servers there is a lot of free one that are very good.
A good Free one is from http://www.youngzsoft.net/ccproxy/
As you can see it does all you want for FREE
Proxy Server CCProxy can do more than what you can image
The first version of Proxy Server CCProxy was developed in June 2000.
It was initially applied to the modem sharing within LAN. As of now, Proxy Server CCProxy expands its supports of Internet connections to many other types, like DSL sharing, cable modem sharing, wireless sharing, satellite sharing, parent proxy server connection sharing, and more. Only if there is a computer within LAN can access Internet, all of the rest computers can sharing Internet connection via this proxy server software. This could save the cost of hardware and Internet connection fees to largest extent for your business.
Below we give you a picture of what this proxy software can do for your business.
It's a web proxy software and it enables you to browse web pages, download files, send and receive e-mail.
It's a web cache proxy and web caching expedites the speed of surfing the net.
The proxy user control provides powerful management functions including seven ways to control the Internet access on the LAN. They are IP address, IP range, MAC address, User Name/Password, IP + User Name/Password, MAC + User Name/Password and IP + MAC.
It's a time schedule proxy software and the time schedule can freely control the users' on-line time.
It can allocate client surfing service respectively. This gives you an authority to open the different proxy services to the different users. Some of them may browse the web pages or send and receive e-mails and others may enjoy all the Internet surfing functions.
It can allocate proxy client bandwidth respectively. The bandwidth control can allocate the different bandwidth to the different users. Thus, it can control the speed of net surfing and occupation of the bandwidth resource of each user and avoid the traffic jam of net, which is caused by some users who try to download files.
Web filter can ban the undesirable sites with unhealthy and irrelevant contents. This proxy software will help you keep the employees concentrate on their work or children stay away from the bad sites.
Access Logging can keep a full set of the Internet access log.
It's a SOCKS Proxy and allows you to use ICQ, MSN Messenger, Yahoo Messenger, CuteFTP and NEC Sockscap.
CCProxy is especially suitable for the small to medium sized businesses. Its affordable cost, powerful functions, and easy to use nature plus our prompt technical support make it absolutely different from other Internet sharing software.
Top
CCProxy Main features
I am not aware that your router can do it.
jlpappin
Ok thanks a lot for your help. I will take a look at it.
