Resetting SAR 110 Router
How can you reset SAR 110 Router :?:
as the password and login are not working Sad
set wrong and cant accesss router though the http://192. way :?
Why is there no reset button Why? :roll:
How do u reset the router or bypass the login/password screen
Is there a backdoor login/password
thanks to anyone that may help in advance
[Moderators note (by Thomas): CAPS removed. Please do not use CAPS to emphasise things... use bold or italics instead. Thank you.]
Have you tried the default username and password? It's DSL / DSL...
plug the serial cable in, at the $ prompt type:
reboot default
the router will reboot with default config
use hyperterminal and different com ports, speed: 9600 and flow control: none - all other settings are default.
Plug the serial cable in, at the $ prompt type:
What you mean at the $ promptHuh
Command line/RUN
Or DOS Prompt
I am running Win2K
(use HyperTerminal and different com ports, speed: 9600 and flow control: none - all other settings are default.) --- Could u plz emphasize how to go about using HyperTerminal not had to use it to reset a router or anything b4 just check a modem.
Thanks you all for your speedy responses so far
And sorry for CAPS Admin Cheesy
You should find the hyperterminal under accessories.
It is on win98se anyway.
If it's not there you may need to install it from your windows cd.
Once you have it intalled just double click on the icon for the .exe file and you should be able to follow the instuction from mwright
All the info you need and loads of help are on Solwise forums
http://www.solwiseforum.co.uk/
Tried what Mrwrite said to do
Serial cable in both router and PC
9600
Nothing on flow control
Went through Com 1-14
There is no com 3
There is no $
I can’t type anything or do anything
I am connected to these com ports or so HyperTerminal says so but I cant do a thing. Sad
Why so complicated.
got this router as package from plusnet, have to pay it off over a year and it looks as if I may go out and buy a new router because i cant stand this.
No matter what com port I connect to I get no $ at all
And can’t type nothing
Any more help advise plz Smiley
Connect the cable to the router.
Connect the cable to one of your COM ports on your computer.
Open Hyperterminal
Create a new connection on (either COM1 or COM2)
speed: 38400
No Parity
8 bit
1 stop bit
Connect.
If you get nothing on the screen, simply power-cycle the router and you should see it initialise on-screen.
when you see a $ prompt, enter:
reboot default
This will reset the router to 192.168.7.1 and the default DSL/DSL password.
Barry
Cable Connected
Open HyperTerminal
Made a connection on COM1
Speed: 38400
No Parity
8 bit
1 stop bit
NO flow control
I then connected. I got nothing
Following Barry's advice Cheesy I power cycled the router and presto things start to appear on the screen and you see the router going through its stages. After a few seconds it on and working and sitting at the $.
Everything great so far except I cant type anything and i need to type "reboot default". I tried everything but i could not get a single character onto the HyperTerminal screen.
Did a google search on "cannot type on HyperTerminal" went to a few search results most forums talking about WinXP and typing into HyperTerminal problems but not many answers.
I am using a Win2k machine so I am thinking this XP problem is the same as what I have so i went to the website ....... http://www.hilgraeve.com and downloaded what they call "HyperTerminal PE" (Private Editions") its free upgrade and meant to be better than Win2K's default HyperTerminal.
So after installing HyperTerminal PE I went to make a new connection with the setting Barry said before. I connected. Screen was blank so I power cycled the router again and the screen became active and went through the process on router startup.
When it got to the $ I could type (could not believe it at 1st) this is with the HyperTerminal PE.
So I typed reboot default
It worked I went into router and went to do all the settings everything working 100% except every time i tried to enter the primary and secondary DNS IP's and submit I got an error but I was online and it figured out the DNS itself.
So everything is 100%
Thanks zubel(Barry), mwright, johnessex, brocco Tongue
Thanks to everyone that helped and for speedy responses
Thanks you Barry for the hint of powering on and off router once connected.... that helped a lot. ;0
I just ordered A Dlink DSL 504 ADSL router last night as well as I had given up
Lol Shocked
Such is life
I hope everyone that my lengthy response might help anyone that might be having the same problem I have had with Win2k and HyperTerminal Smiley
Thanks everyone Cheesy
P.S anyone need a Solwaise SAR110 Wink
I could not get into my router for a month and my PlusNET connection never went down.
Very Happy PlusNet Customer Cool
You could always sell it on the For Sale forum Smiley
lol cheers
Tongue
Just a word of warning though. Cool
Don't loose the password on the D-Link as its a similar procedure to find it, but with a deeper dig into the innards via the parallel cable and hyperterminal.
I know I've been there Cry
Cheers. I remember that Cool
That 2 big?
I have split off a section of this thread. The split part can be found here.
Thomas
That makes sense since it ws going some what off topic Shocked
