Request for help from other LinkSys WAG354G users
Hi
I am looking to download and install a firmware update,but I see on the LinkSys website there are two
WAG354G v1.0
WAG354G v2.0
How do I go about finding out which one I need? unless there is a clue in the firmware verion in use at the moment which is Version: 1.01.05
The one (v1.0) gives an upgrade to version 1.01.11(Annex A) whatever that means and the other(v2.0) gives an upgrade to 1.01.54
Just not sure which one I should go for.
Thanks in advance
Walrus
There are 3 different firmwares....
WAG354Gv1 Annex A
WAG354Gv1 Annex B
WAG354Gv2
Annex A is most of North America and Europe, Annex B is Germany only.
From your version number alone (and guessing you aren't in Germany) I'd guess is was a v1 Annex A. However you should be able to confirm this by finding the label on the underside of the device.
I'd also have a quick scan over the Linksys forums.... http://forums.linksys.com/linksys/board?board.id=DSL just to make sure there are no 'caveats' associated with particular firmware versions.
All sorted.......Thanks
