Removing software?
silvercliff
Removing software?
Hi Folks
Can any one help please!
I did have Panda Anti-virus loaded to my PC I unloaded it but their is still some left in the system, and will not budge. I have tried reloading Panda again and then trying to remove it again, but it will not clear. (Ideas please)
I am now using Bitdefender8, this is cheaper and is recommended by most of the Mags:?
Obliged
Removing software?
Just a guess, but did you ensure Panda was not running before you uninstalled? Often, bits do not clear properly if the app is in use (esp. with windoze).
Removing software?
You can also try uninstalling in safe mode...
