Remove Icons
Remove Icons
Hello
Not sure if ths is the place to ask abou tthis matter
The icons on your screen bottom right hand corner how do i get shot of them , i know i can remove them for one session but they return when i reboot my pc.
Most of them I do not use and if I could would like to remove them from screen but not my system.
Thank you for your help
Alecto
Remove Icons
They relate to programs which are initiated at startup.
click Start, Run, type in msconfig and press enter
Then click the startup tab and untick the things you don't want to start up.
There is a nice little free program called startup monitor that keeps an eye on this for you and warns you when any attempt is made to add programs to your startup list. You can find it on google, or download it from here
Alecto
Remove Icons
And if you want to find out what some of the many programs that start with your computer are, then this website lists them all and tells you what they do.
Remove Icons
Thank you for your help I will give the advice ago now , thank you again for your help
