Remote access
Remote access
Looking for some advice here, can someone help me to set up remote access on my home network, I would like to be able to access it from work.
Not sure how to go about it I have a Netgear DG834 router and XP pro.
Cheers
Donald
rhosybol
Remote access
Well there is Real VNC or PC Anywhere, these should help.
Cloudmaster
Remote access
Do you want access to a number of machines on your network or just one? If it's the latter you can use the 'Remote Desktop Connection' facility of XP for this. You'll need to forward port 3389 TCP from the router to the IP of your XP box & at the office as long as you're running Windows 2000 or greater you should be able to connect to your XP box from there but.........
Your office may have a firewall in place preventing this
If it does work password protect your XP box & if you can, only allow connections to this port from your office IP (if it's static)
Remote Access
Cheers guys I will have a go at that, I only want to access the one machine.
Donald Cheesy
Remote access
Hi again
I have forwarded port 3389 TCP from the router to the IP of the XP box but when I try to connect from work it just comes back and tells me it couldnt contact the remote PC.
Is this caused by the firewall at my work, if it is is there another solution to this as I wont be able to get anything changed at my work end.
Cheers
Donald
Cloudmaster
Remote access
On your XP box, go to control panel >> System (assuming classic view here) >> Remote tab
The 2nd check box should be checked, it's all fairly self-explanatory
Remote access
Cheers ,
Just done that and will check it out tomorrow from work. Smiley
Donald
Remote access
u need to forward UDP 3389 as well
Cloudmaster
Remote access
Not according to Microsoft
Remote access
radmin is the best program ive found, it beats vnc hands down, it uses little resources and is stable, unlike vnc
linky : http://www.radmin.com/
hope this helps
Remote access
If you are trying to connect using a win2k client it wont work you need to download the xp version from MS
Remote access
ma bad, im sure i read somewhere you need 3389 UDP done as well *shrug* but you are right that on the MS site it says nothing about it.
soz
buzz
Remote access
pc anywhere is thw way to go with encripton as i use this my self and help friend sort their computers out as well
