Remote Desktop
Remote Desktop
I am having difficulty in using remote desktop.
I can log in easily and can see my desktop etc etc. But say i click on start menu or any icon...thiers just no action. It stays the same. Both machine is windows XP.
Any ideas
Remote Desktop
over the internet? or over a LAN?
if its over the internet it may just be lagging like hell, make sure you set the "experiance" to 28k so youi get the best response.
Remote Desktop
Its over LAN
Remote Desktop
then i have no idea.
Remote Desktop
Is this at home or work? Are you logging in as yourself or admin? what do you need RDP for?
Remote Desktop
make sure that you have it enable on all pc you wish to connect to first then make sure you have an account on each machine noting you may only logon onece per machine in the same name.
Remote Desktop
You must enable it in start/control panle/system/remote and tick both boxs for allow and set up the user names
Try this
It's a great little tool called(Google for it)" UltraVNC Viewer", you can control another PC with it, I do it over a wireless LAN to help my wife.
It is a free DL.
Remote Desktop
think its realvnc you need to look for rather than ultra
