Quicktime conversion
jabb0
Hey guys,
does anyone know how i can convert a .mov file into something i can put on a CD and then put the CD into a DVD player (like the one u have in your front room)?
I have searched and been trying for hours but nothing.
PLZ help!!!
PS a windoze exe file would be nice.
holdtight
Hi
There are quite a few vid converters about some free some not and a google search should have brought up loads
The one that i personally use for all my conversions is Radtools by bink video and i can highly recommend it as a very useful bit of kit
It will transfer your .mov files into more or less what you want within reason ie avi mpeg mpeg 2-4 and back again if you like
It does require some getting used to though but is quite easy once youve done a few so back up the files your working with first and have a good read of the docs
It is a windows exe and its also free
Bill.
jabb0
That was one which i had tried, but it only ever managed to get the sound converted and not the video.
i have seen this come highly recommended on a few occasions on my search.
if you would be so kind i would realy appreciate it if you could tell me the buttons you have pressed to get it to do the job.
I am at my wits end - and wonder why o why the folk who make digital cameras decided it would be sucha great idea to use a format which is not nativley supported on PC's, Macs, linux or DVD players.
thanx
holdtight
The first two links that Peters given you describe how to use rad very well and i cant really add any more to it
I did find that when i started using rad i had to experiment with the final output codec to get the best result bitrate and filesize you may have to do the same
If you still get stuck give us a shout
jabb0
kewl guys thanks alot.
