Printer Sharing Acrobat Reader
Fixes: 57
I have an interesting problem which I haven't been able to solve.
My printer is attached to a Windows 98SE machine and I can print from my XP machine with no problems at all except for acrobat documents.
It seems to be due to the fact that the XP machine is running Acrobat 7 and the 98SE machine Acrobat 6 as everything was OK until I upgraded the XP machine to version 7.
Any way round this. At present I wander over the 98 machine open the file from a network share and print it locally.
Gryzor
Does the printer get to the print queue?
If it does but you get nothing have you tried the 'print as image' option? That tends to fix all sorts of Acrobat printing problems.
Fixes: 57
It normally just crashes Acrobat as non responding.
However your suggestion about using Print as Image fixed the problem.
