Printer Problem -- USB extended cable
seasider
Hello,
I've got a samsung printer CLP-500 it's too big to sit next to my computer
so I have put it on the other side of the room.
To connect to it I run a USB cable around the room.
I've had to use an extender cable because of the length.
when it works everything is fine but once I stop printing the link seems
to die after a period of time and I can no longer use the printer until
I disconnect the cables.
(sometimes I have to pull the cable out of the back of the computer
sometimes I pull it out of the printer sometimes I pull
the USB out of the extender cable,
sometimes I have to pull all the connections).
Rebooting the PC doesn't always help.
If I disconnect and reconnect enough of the cables then
eventually the printer comes back to life.
Does anyone know of an easier way?
Have you tried a USB repeater cable?
They're available from ebuyer (quickfind number 48184) and allow you to extend the range of a USB cable beyond the normal 5m limit.
Hope this helps. Smiley
seasider
still got the problem
Yes the extender cable I'm using is an active repeater.
Thanks anyway, I also have a wireless lan, I'm wondering if
using a wireless ethernet connector for the printer might solve
the problem. Has anyone tried one of these?
