Power supply
zpeterk
Power supply
Hi all
Want to use computer power supply to run case fans to keep an amp cool (PA), which pins need linking to turn on the supply?
Cheers
Power supply
I had to do this recently when i installed my water-cooling kit.
If you open up this PDF and scroll to page 32 there is a guide on how to do this Cool
Power supply
Hi
ATX power supply is pin 14 and one of the grounds.
See the red star and arrows.>
Linky
EDIT. Dragged my feet posting. The post by paco2k5 was enough. Doh!
[Moderator's note by James - (sallyandjames): Changed image to a URL as it was stretching the page. Wink ]
Power supply
Actually that’s a nice little guide also ^^ ill save that now Wink
zpeterk
Power supply
Thanks guys
Power supply
Would you not be better off purchasing some mains powered fans, or even a cheap 5/12 volt power supply?
Using a PC power supply to power a little fan is a little bit of an over kill.
Take a look at http://www.maplin.co.uk/
Chilly
