Port Forwading - anyone help please...?
I am having a problem Port Forwarding on my Router. This is enable me to use p2p software (µTorrent) effectively.
My Router is a MentorWireless-G.
The Ports were forwarding correctly for ages - when I ran the following check: http://tinyurl.com/y8hptg
it reported that the port was forwarded correctly and accepting incoming connections - like this: http://tinyurl.com/yehplz
Then all of a sudden it has stopped working.
I have followed the instructions to set up a static IP address from here: http://tinyurl.com/5uq3w
this means I have the following set up in the properties of my Internet Protocol (TCP/IP): http://tinyurl.com/yn58o3
Then, I have tried to follow the specific instructions from the Mentor section at: http://tinyurl.com/j6kzd - but none of them relates exactly to my router. So using my limited understanding (the documentation for the Router is poor) I have connected to my router, and mapped the port as follows: http://tinyurl.com/ymuwxb
Then all of a sudden it wont work. I have tried several ports - Sometimes I can get a Port open - very briefly -, but it wont last - then when I check via http://tinyurl.com/y8hptg it says the port is not accepting connections - like this: http://tinyurl.com/yehplz
Other things I tried.
- Tried ports in the 50000 + range
- Switching off my firewall
- Switching off my virus guard.
- I have tried setting up in the properties of my Internet Protocol (TCP/IP) to be 'Obtain an IP address automatically.
Questions
Am I missing something ?
why did it work for ages then suddenly it wont ?
what is causing the port to stop accepting connections ?
can someone tell me what this php script testport.php is doing ? (checking the port is open is the obvious answer)
Any ideas appreciated.
maybe...
What port/s are you trying to forward?
I let utorrent choose one randomly - they are usually in the 50000 + range
OK.
In which case, set the port for Utorrent to what have you (50000 or whatever) and then forward that specific port from the router to your IP address.
thanks rynth - I've done that right from the start -
humm..
you have remote access to this router? i can dial in and get one of ours comm's guys to check it out for you.
sorry - what do you mean do I have remote access ...??
if I goto http://10.0.0.2 from browser I can access my Router ?Huh
if you give me your external IP , and then PM me the user/pass, ill get one of our guys to check it out.
im from here by the way - www.keystonegroup.co.uk
I'll do this when I get home ... cheers
No probs.
PM'd those details ...
