Porlbmes with third party cookies
hi
i recently had problems with not been able to download when left clicking i was directed to some porn site everytime i cliked a link, it was the same site
i can get rid of the problem using adaware but when i reboot computer my home pages and everythign goes back to the problkem before
how od i delete it to stop it editing my settings in ie?
cheers
There is a program called SpyBot Search & Destroy which is similar to AdAware, but a lot more thorough. I would suggest giving this a go.
Note: Be careful when using this. Always use the program's "Backup" facility before making any changes, and only delete items which you are positive are spyware.
hi
got that installed as well
they remove the problem until i reboot then everything is back
it must be in the startup files ot load somewhere but i have nooooooo idea how to configure it or anything like that
its definately when i restart the pc it comes back
cheers
chris
Remove the program with your spyware removal proggy as you have done before. Then open “start>programs>accessories>system tools> system information"…. Open the tool menu and click on system configuration utility. Click the startup tab … Scan down the list that comes up and untick any program/ file that you don’t want to start on boot up . Hopefully the program that you don’t want activated will be there. Click ok when you are happy with the startup list . Reboot and hopefully the annoying little prog will have disappeared.
Hope this helps
Phil
