Php just spoils us
jabb0
Php just spoils us
Doin a little work in C++, and i am more or less a complete noob.
I have written this function :
int GetDirections(int startX, int startY, int finishX, int finishY)
static int newDirection[2];
int directionX;
int directionY;
directionX = finishX - startX;
directionY = finishY - startY;
newDirection[0] = directionX;
newDirection[1] = directionY;
return newDirection;
but it says
error C2440: 'return' : cannot convert from 'int [2]' to 'int'
I dont want it to convert it to a single int, i want my array returned out of this function.
The answer is prolly sooooooooo simple im gonna have to hurt myself for being thick.
As i said im kinda new to this, i can program, just not in C++... yet :roll:
Php just spoils us
meh, you are trying to return the array, not a value in the array, you would have to do
return newDirection[1]
return newDirection[2]
i think
prichardson
Php just spoils us
In order to return an array, you will have to have to deal with it as a pointer.
IE, instead of returning the array directly, you return the pointer of the array, which is an int.
Php just spoils us
Something like the following should work
int *GetDirections(int startX, int startY, int finishX, int finishY)
int directionX;
int directionY;
// return the address of newDirection
return &newDirection;
int *var;
var = GetDirections(sX, sY, fX, fY);
var[0] will point to newDirection[0]
var[1] will point to newDirection[1]
Also be careful of the following:
int *var1, *var2;
var1 = GetDirections(sX1, sY1, fX1, fY1);
var2 = GetDirections(sX2, sY2, fX2, fY2);
Because var1 & var2 are pointing to the same static variable within the function, as soon as the 2nd line is called, var1 & var2 will both point to the same values as defined by the 2nd call.
You need to read up on pointers and possibly structures.
