Photoshop 5.0 Limited Edition
Hey,
Ive got Adobe Photoshop 5.0 Limited Edition, in which i can change images size, can i do a batch of images at the same time? if so how? Thanks in Advanced,
Tim
p.s. If not does anyone know a free program that does?
[Moderator's note (by csogilvie): Topic moved from CGI and Scripting.]
bobgidden
I can strongly suggest IrfanView, a free graphics viewer, but it does all sorts of cool stuff as well.
http://www.irfanview.com/
Batch Conversion:
Use the Advanced Options button to apply many special operations to the images during conversion. These options are much like their versions on the Image menu. The options are:
Crop, Resize, Insert text, Change color depth, Horizontal flip, Vertical flip, Rotate left, Rotate right, Convert to greyscale, Negative, Sharpen, Gamma
Correction, Contrast, Brightness, Saturation and Color Balance.
Regards,
BobG
Just a note. Limited edition inAdobe terms actualy means Lite Edition.
THese are very feature impared versions of there software and supplied on an OEM basis with scanners and digital cameras.
I used the following app to convert the size of many graphics images and avatars. The trial version only allows conversion batches of 6 files at a time so you can try it out. If it's any good you can buy it.
Advanced Batch Converter for Win9x/NT/2000/ME/XP
Advanced Batch Converter does exactly what its
title suggests, allowing you to easily convert
multiple graphics files at the click of a button.
More than that, you can also edit images directly
in Advanced Batch ConverterT, to produce a variety
of effects (resize, rotate, flip, mirror, crop,
filters, morphing effects, color enhancements...
License: 30-day trial
Website: http://www.batchconverter.com
E-mail: support@batchconverter.com
