Partition Software
Partition Software
Does anyone know of any software akin to Partition Magic, which will work on Windows 2000 Server?
Partition Software
PMagic 7 and above works on 2000 pro / server + sp4 without issues, I'm currently using v7 on my server to move some partion space about for easier defragging. It's the one utility I keep on floppy as well, never know when you'll need it, handy for lans when someone is having problems and can't use a Boot CD
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Partition Software
Not according to the version I have (Partition Magic 8.0) - "PartitionMagic does not support Windows NT Server or Windows 2000 Servers." : taken from the ReadMe file. It simply will not install, it stops with an error message.
Partition Software
hmm always thought it did, but never used 2k Server but they made a Server edition, to get more cash from it I think, it has a 15 day trial ware. If its a one shot wonder your needing then worth a go, if worth it maybe buying it as well Wink
Partition Software
PM is very naughty trying to get you to use the server version and 10 times the price. Strangley version 5 works ok I have tried it on 2kserver and advanced server and it doesnt complain about the server.
Acronis www.acronis.com do a nice one or Vcom http://www.v-com.com/news/news_ar33.html
Or freeware
Ranish - aka "Partition Manager"
http://www.ranish.com/part/
There is also Zeleps Partition Resizer 1.3.4, you can find it at:
http://www.drd.dyndns.org/cgi-bin/download.cgi?FileID=5592
