PS2 - PC pad converter
i bought a Playstation 2 - PC pad converter from play.com
http://www.play.com/play247.asp?pa=stts6&page=title&r=PC&title=114167
which came with barley any instructions (just 'install drivers')
i installed the drivers, which did nothing except make the pad vibrate when i play NFSU2 (still have to control car with keybord)
i used this guide: http://www.nbka.net/ to get rid of the drivers and get back to square , as it said to use the pad without drivers, which worked, kind of.
now when i play NFSU2, i can controll the car with the PS2 pad, but theres no rumble. ive re-installed the drivers and tried to deliete specific files out of the registry which it installs, but no luck, either control or vibration, not both.
i even tried drivers for other brands of PS2 to PC converter, but they didnt really help, still one or the other.
Is anyone expirienced enough with the registry to know which bits to remove/tweek, or got another fix for it?
help would be much apriciated
