PDA Newbie Question
PDA Newbie Question
If I get a PDA with Wi-Fi capability and connect at a "hotspot" be it "BT Openzone" or "The Cloud" will it be possable to access my Plusnet account for recieving and sending emails other than by webmail....... or is mobile life not that simple?
Thanks in advance
IanJ
Plusnet Staff
Plusnet Staff
PDA Newbie Question
You'll be able to receive fine, just set up the mail software for POP3 or IMAP and it should work fine.
Sending though is slightly different. You can only send via our mail servers when connected to our network so you would either have to send via webmail or using the hotspot's SMTP server (if they have one).
PDA Newbie Question
Ok thanks Dave..... and happy New year
