PC bundle and case 400W PSU
Is this case any good for this bundle I have been told that the PSU are crap Huh?
This is the case and website where I am thinking of getting
http://www.advancetec.co.uk/acatalog/AMD_64_UPGRADE.html#1854
Or still buy it and get a new PSU
Moderators note by John (johnessex) Title and text changed from all capitals which is shouting on the internet.
Also this topic seems to be virtually the same one as your earlier post on the subject.
Please keep to one post for this issue.
You would get a better deal buying the same equipment seperatly from a major retailer like scan, dabs or savastore.
Might also be worth investing in a keyboard which has a working Caps Lock key Wink
LOL ^ ^
That case is horrible, it will probably be realy flimsy and razor sharp and the psu wont be good enough for a decient 64bit setup.
When i design a pc the most important things i look for are a good quality motherboard to build your system around. Dont skimp on the PSU, a quality PSU will give good system stability and dont skimp on your case either, it will need to good enough to put your lovely new components in.
