Overheating Plug - D-link DSL-504 Router
Hey, I have a D-Link DSL-504 router and the router itself is fine, it's the plug I am concerned about, it seems to heat up quite a lot and makes a faint buzzing noise that u can hear if there is silence. Just wondering if this is normal.
Ianwild
Unless it gets too hot to touch then this isn't a big deal I don't think. At least, my router transformer gets above what you would describe as warm, but not what you would describe as boiling...
Col thanx dude that will ease my worries Cheesy
I have a D-Link 504 as well and like you I find the transformer / Plug runs hot.
I have had it running for several months now and this seems to be the norm.
As Ian says if you can still stand to keep your hand on it then it should be ok.
My 504 adapter also runs quite warm, so I guess this is normal for this particular model.
GM
edde
Mine runs 24/7 and is currently 34C, they do run warm but should never be too hot to touch, if it is then there could be a prob!
