Outlook re-install
morgan2476
Outlook re-install
Hi folks
I have just set up my system and installed outlook again - a couple of we problems -
1. How do i set it up so send/receive starts automaticaly when I start the program?
2. All the fonts are some basic sort of font - how do I change the text?
1 REPLY
Discostoo
Outlook re-install
off the top of my head,
1) Tools, Options, Mail Setup - There should be a check box or option there...
2) Tools, Options, Mail Format tab, there'll be a font button. Just choose and save. But if you select any stationary or themes, the fonts will change unless you override this using a check box that says something like "always use my fonts"
I use it in work so i cant get to it right now, hope that helps...
