Outlook express question
ok heres my problem, i have two pcs, ones mine and the other belongs to my dad, when i check my email (user1@username.plus.com) i also recive my dads (user2@username.plus.com).
I was wondering if it would be possible to recive my email ONLY on my pc, and my dads on his.
any help appreciated.
You will need to set up two mailboxes, one for you and one for your dad.
Then each PC will have to have the email acciunt set up for the relative person.
It is explained here.
https://portal.plus.net/supportpages.html?a=162
so it is Cheesy
didnt see that, thanks for the help Smiley
Also remember at least one system must also collect email from your defaultmailbox as this is a PlusNet requirement - i.e. you must have an account setup in OE which logs in as username as you have been doing.
PlusNet often use postmaster@username.plus.com to send you email but there may be email sent to other names at your domain which you need to look at/delete on a regular basis.
