Outlook Express Problem
penneck
Just lately, when I start Outlook Express, it is more likely than not, to complain that it has done something illegal, and give me the choice either to close Outlook Express or look at the details. If I close Outlook Express, and immediately try again, it always starts successfully at the second attempt.
If, instead of closing, I look at the details of the failure, I get the following:-
MSIMN caused an invalid page fault in
module MSHTMLED.DLL at 0177:70f72931.
Registers:
EAX=03490144 CS=0177 EIP=70f72931 EFLGS=00010202
EBX=0280d100 SS=017f ESP=00565548 EBP=00565558
ECX=00000000 DS=017f ESI=00000000 FS=6abf
EDX=00565620 ES=017f EDI=00565620 GS=0000
Bytes at CS:EIP:
f6 46 04 02 74 75 8d 45 08 50 ff 75 0c e8 f0 fc
Stack dump:
0280d910 00000000 03490144 00000000 005655b4 70f398ff 0280d100 0047e040 00565620 70f424bd 03490144 0280d100 0047e040 00565620 00000000 637ba83f
I have re-installed Internet Explorer, which I understand is the source of Outlook Express, but the problem remains.
If anybody in Plusnetland has a cure for the above, I'd be grateful to hear about it.
Many thanks
Graham Penneck
Alecto
Graham
Try googling all or part of the error message
MSIMN caused an invalid page fault in module MSHTMLED.DLL
You get quite a number of different suggestions as to what may be causing it depending on what you're doing at the time, and you may find your own circumstances in there.
If not, I suspect you're left with reloading windows, or if you can't be bothered with that you could use Thunderbird for your email till you can be.
MSIMN - wouldn't that be MSN / Windows Messenger?
Alecto
Process File: msimn or msimn.exe
Process Name: Microsoft Outlook Express
Description:
msimn.exe is the executable for Microsoft Outlook Express, the default POP3 email application included with Microsoft Windows. This process should not be removed while you have Outlook Express open.
I stand corrected - a quick google later it actually stands for:
MicroSoft Internet Mail and News
jabb0
I no longer use windows, but when i did, the fact that msmessenger was needed to load outlook expressed really ticked me off cos i neva used it.
A solution would be to download a program called
X-Setup
A nice little programs which to a certain degree takes the hood off windows and gives you access to a few extremely useful options which MS couldnt be bothered to make an interface for.
Anyways after a bit of looking around the many options, you will find an option to stop outlook trying to load messenger.
Granted the program name of messenger is msmsgs, and not msimn - if i were a betting man i would bet this would solve your problem.
holdtight
If MS Messenger really ticks anyone off just copy and paste this into the run box and hit enter
rundll32 setupapi,InstallHinfSection BLC.Remove 128
%SystemRoot%\INF\msmsgs.inf
gone goodbye and good riddance !
penneck
Thanks to all for your advice. Unfortunately that annoying niggle is still there in spite of all your suggestions. I've even tried reloading W98SE over the existing W98SE, and I've tried reloading from an image of my C drive that I thought I'd made before this problem started.
I guess I'm going to have to live with the problem or try another e-mail process (Thunderbird or Courier or something).
Regards to all.
Graham Penneck
