Outlook 97 Calendar
teebee30
Outlook 97 Calendar
I use Outlook 97 as my diary / calendar. But when I view a single day or a seven day screen, it shows the date but does not show tha actual day e.g. Monday.
Does anyone know if this is standard with this programe or if there is any way to fix it ? Cannot find anything on the Microsoft site.
Have viewed programe on friends computer and thay also have same problem.
The days do show up in monthly view !!
Not very convenient for a diary. : :?
Outlook 97 Calendar
Not directly no... Wander over to www.wopr.com.. Click on the link to the 'Lounge'.. Great forum for support on all things Microsoft.
teebee30
Outlook 97 Calendar
Thanks for info.
Checked site but their search engine is out of action fttb
Will check later
Outlook 97 Calendar
Search has been down since May sadly... Just post a new question.. If it cn be done, someone will get back to you.
