Opportunistic file locking
zpeterk
Is this only used by novell, 2k and XP or does the ms server versions use it as well?
1 REPLY
Any O/S that uses networks can use file locking. There are lots of articles on MS knowledge base about problems with it like
http://support.microsoft.com/default.aspx?scid=kb;en-us;812937
if you search the KB for Opportunistic file locking you will find a lot of articles.
The KB is here
http://support.microsoft.com/default.aspx?scid=FH;EN-US;KBHOWTO
